Pauly99to17
Ya, but these things are measured to be so snug that they won't be going anywhere.What they lack to reach perfection is some grommets for the floor hooks![]()
They're great as they are for sure. The mat itself is adhering to the carpet as well so it is good. For the Civic we need the plastic grommets with the oval opening to accommodate the turn to lock approach they have. Did not see any of those available anywhere.Ya, but these things are measured to be so snug that they won't be going anywhere.
Ya, you know I didn't really thing about the mat might have a bump in it where that turn grommet thing is. I may have to cut a small hole there so it sits flat. Will need to check that out.They're great as they are for sure. The mat itself is adhering to the carpet as well so it is good. For the Civic we need the plastic grommets with the oval opening to accommodate the turn to lock approach they have. Did not see any of those available anywhere.
Got the badges today.I haven't ironed them on yet. I might trace the badges and then shave the rectangle into the carpet so that the badges will be flush.
Ya, true dat!That would look good. Just be careful that the material won't fray when you cut it.
Ya, good idea Webby....thanks! I have some extra to test on.^what andre said. You may find that cutting/shaving into that will cause threads to pull/fray further and further over time. Maybe do some test cuts on another piece of scrap to see how it reacts to wear/vacuuming etc?
No, under the badge you can see a shiny plasticky film that melts when heated.the nylon or whatever in the carpet most likely is melting...
Okay....good to know. I'll be doing some testing for sure. A+ahh... well your carpet may do some melting as well. We had an incident with an iron/carpet quite a few years ago. It didn't "burn" the carpet, but it left a decent mark. Essentially singed the carpet in a spot and left an area where all of the fibers shrunk if you will? It was a berber industrial type carpet.
And no one can fit behind the driver anyway.......... at least not behind me, mines all the way back.......Maybe that one locks in because people get in and out from behind the passenger seat and it moves a lot?
The Si badge on my driver's mat came off in just a few months and I saw that they use some kind of glue from the factory. I just hand sewed it back on, pretty easy to do and no need to worry about it coming offOkay....good to know. I'll be doing some testing for sure. A+
I used needle nose pliers lolIf you hand sew, get a thimble......
