pssstitsmike
- 105
Look at the previous posts on where to see the firewall plug. Its near the fuse boxHow did u get thru firewall? It's hard i cant even see it -___-'
Make sure you buy the add a circuit to mini fuse to tap into accessory for the green wire. Other than that it is simply 2 black ground wires and white power wire goes to battery. Make sure you buy a terminal connector to hook it up to the battery. Good luck with the install. Takes about 3 hours from start to finish. The bumper is easy to remove. Its just 12 clips on the bottom 2 screws on each side near the tires and two screws on the grill n a few clips therehow about the fog light relay and the green?
Oh ya, easier for you guys with coupe.with the coupes the blank just removes and the fogs are supposed to pop right in. the mounts are all set behind it too im glad i dont need to cut lol
if they line up lmaoOh ya, easier for you guys with coupe.
the gaps doenst bother me though. U have to be super close to it to notice it. I like the fog lights even with the gap. A lot cheaper than the oem honda fogsyeah i didnt leave them in.... im waiting for op to chime in because he has an lx coupe just like mine
after the fitment issue i havnt played with them im still pissed. im gonna see pricing of those shrouds at my dealer.
The button is just fine. To get 7000k or 8000k color u need hids.Got mine in the mail. Button feels a little cheap. Does it look and feel okay once in the slot?
Did you keep the bulbs that are already in the lights? How are they? I will guess not so good and probably cheap and won't last long. ????
If I order bulbs, I'm looking for plug and play. I would like them to be white with a blueish shade to them.....say 7000k - 8000k. Anyone have a suggestion of which bulbs to order......if I even need to. Appreciate any help you can give.
Are you using the bulbs that came with them?The button is just fine. To get 7000k or 8000k color u need hids.
