Thinking about getting some springs when I get back from vacation to get rid of that awful wheel gap...not sure if I'll go with Eibach Pro kit or H&R Sport Springs
I don't want to go too low because the roads around here are terrible and I have to drive this car in the winter
Coilovers? If the roads are as horrible as you say, you may end up replacing shocks a lot earlier than you might expect. At that point, you may as well have just bought coilovers in the beginning over springs.
Or a Spring/Strut combo. The wheels look great.
Thanks for the info! I'll see how much extra money I have kicking around after my semester and I get back from Florida for vacation
Well, there is your problem. You are spending coilover money on a vacation to Florida!![]()
Nice! Haven't seen an update from you in a while!
A full koni/spring setup with all new parts and strut fab with camber arms will run you about $1450 from Redshift. Koni's require some heavy modification of the front strut. That price includes new ones so you will have no down time with your car.
I don't live as far north as you but I was concerned that the threads on coilovers would get eaten and destroyed by salt/sand/winter conditions so I opted for the spring/strut setup instead. I don't think you would have an issue with either the eibach or H&R drop in the winter.
The new HFP suspension apparently offers about the same drop now at just over an inch. For less than $1000 it includes the stiffer struts and is a great way to go for a DD.
Nice TeeEyeVany. I need to clean my engine bay too. Lol. How did you clean yours? I'll use a degreaser (sometimes) and use a foam gun. Then a good rinse with a hose and sprayed dry with an air compressor. ABS and alternator covered.
A bunch of 8th owners go with the Koni Orange for the front bc it's less of a hassle than cutting the stock struts. But they lose the ability to harden the dampening.
