WhiteWillie
Can anyone tell me, Is a 1/2 inch torque wrench, with maximum torque of 150 ft/lbs, adequate to work on an Si?
Thanks in advance.
Thanks in advance.
Whatever the range is, the torque wrench will be most accurate in the middle of it's range. So a 0-150 is mot accurate around 75-80lbs, perfect for lug nuts.
Might want to look into a smaller one with a shorter range for a lot of the other bolts with the approx 30lb torque specs. Lots of suspension parts fall in that range.
Walmart and Autozone have a 1/2" drive, 150 ft-lb wrench for about $30. I don't know how accurate it is, but I'm not using it to make my living, so it should be good enough. It has a nice, long handle, so it's good for lug nuts. Buy a 6" straight extension to put on the socket so you aren't scaping your knuckles on the bodywork. They also have a smaller, 3/8" drive, 10-80 ft-lb one for about $25, which is good for brake calipers, etc.
The funny thing about the smaller one is that the handle is marked in "inch-pounds" , in 120 in-lb increments, (120-960), along the shaft, while the smaller graduations on the handle go in ft-lbs, from 0-9. So, to set it for, say 24 ft-lbs, you have to set it to 240 in-lbs on the shaft, then turn to the 4 on the handle. Apparently, the people who were putting graduations on the handle weren't in contact with the people who were putting the graduations on the shaft.
Lugs are 80ft lbJust bought this one from Canadian Tire. On sale for $60.
It has maximum setting of
- 3/8 inch, couple de 30 to 250 lb-inch (4,5-29,4 N )
So, I have read that 80 lbs is the correct force to set it at for tightening lug nuts. Is this correct? The guy at Canadian Tire told me 100 lbs.
http://www.canadiantire.ca/browse/product_detail.jsp?PRODUCT<>prd_id=845524443290632&FOLDER<>folder_id=1408474396672077&bmForm=form_locale_change&bmFormID=1382192120286&bmUID=1382192120286&bmLocale=fr_CA
Nice. How cool is that!?Lugs are 80ft lb
This is a great resource-
http://www.collegehillshonda.com/instructions/civic/2012/4dr/civic_torque_specs.pdf
http://www.canadiantire.ca/browse/p...2192120286&bmUID=1382192120286&bmLocale=fr_CA
Nice deal I got on it eh?Pauly, that the same wrench that I have. It is 80lbs for our car.
Now that is a great price.I bought a 1/2" drive 20-150 ft-lbs torque wrench several days ago. It was on sale for $11.99 at Harbor Freight.
