Biohazard
Hi everyone, Many of you know me from 8th civic and here on 9th civic. I thought I would post a build thread of my new track toy as I recently sold the S2000 CR that I used to play with. I have been a Honda man for 20 years now and only recently moved over to the dark-side. My heart is and will always be with Honda but for now my stable has 2 BMW in it.
2003 BMW E46 M3, 6sp manual with 31,500 miles on it.
Updated Mods so far:
Suspension:
*MCS (Motion Control Suspension) 1-Way Non-Remote (1WNR) Single Adjustable Damper Set with hyperco coils 600 and 700 and ground control camber plates and adjustable rear perchs.
*Rogue engineering performance FCAB
*Front Strut reinforcement plates
*OEM RCAB with BimmerWorld Trailer arm limiters
*AKG Sub-frame reinforcement
*Hotchkis front adjustable sway bar
*Rogue Engineering Front Racebrace
*ECS adjustable lower control arms
*AKG Differential and Subframe bushings 95A
*TMS bump stops for steering rack
Brakes:
*Stop Tech Trophy Kit ST-60 front and ST-22 rear
*Stop Tech SS lines
*Pagid RS29 Yellow Pads
*Motul RBF 600
*Hard MotorSports Brake Ducts
*Hard MotorSprorts 355mm backing plates
*Bimmerworld high temp brake duct hosing
Cooling:
*New OEM hoses
*BMW motorsport thermostat
Motor:
*LiquiMoly and Motul fluid replacements for whole car
*AFE intake elbow and drop in filter
*Rogue engineering Octane short shifter kit
*Oil cooler divert valve
*Bimmerworld track motor mounts
*Bimmerworld sport Reinforced Urethane Transmission Mount Set
*SS clutch line
*magnetic drain plugs
*Status gruppe section 1 with rasp eliminators, section 2 resonated, exhaust with black tips
*Status gruppe version 3 headers
*Epic Motorsport Race tune
Wheels and tires:
*Bimmerworld race bullet nose studs and lug nuts
*Apex ARC-8 18x9.5 + 35 (Black)
*Apex 12mm spacer for rear and 5mm for front
*NT 01 275/35/18 (dry track conditions)
*2nd set of ARC -8 (Hypersilver) with Michelin Pilot Super Sports for rain 265/35/18
Exterior:
*flat black kidneys
*flat black gills
*Bimmerworld Tow Straps
Interior:
*Sparco 330 steering wheel
*Momo hub
*Rogue Engineering Quick Release
*OMP HTE Halo bucket Driver
*OMP WRC Bucket Passenger
*Schroth Profi II for hans harness driver and passenger
*Vac Motorsports seat mounts with submount and fire exitinguisher
*Raven Performance Bolt in 1/2 cage/roll bar
*BMW Arm rest delete console
*AKG Pedal kit
*Broadway mirror
Custom Aluminum Trailer for car
It was 100% stock,
now it is not.......
Brett's BMW ///M3 (E46) @ Roebling Road flyby 3 - YouTube
Suspension:
Brakes:
*Stop Tech SS lines
*Motul RBF 600
Cooling:
*New OEM hoses
Motor:
*SS clutch line
Wheels and tires:
Exterior:
*flat black kidneys
*flat black gills
Interior:
*Momo hub
*AKG Pedal kit
*Broadway mirror
It was 100% stock,
