2012hondakid
i was thinking about replacing my stock speakers in my lx to something more. since all the bass is in the doors it seems.....what you guys recommend for speaker selection? and is it easy to change out ?
I have 2 Infinity speakers and 2 Alpine speakers to put in along with a sub and an amp. I'm waiting for a friend to help me out to install all of this.If you plan on replacing the speakers in the rear deck, be prepared to rip out all of the panels in the back seat. This includes the air bar covers, side panels, and back deck. I believe you will have to disconnect the seat belt anchor bolt as well. You will also need to purchase low profile speakers and an adapter. Last I checked, there were no specific adapters for the 9th.
Sounds long to take the rear deck apart. I assume these parts are all just clipped in. ?
What do you mean adapter?
Thanks. So did you make your own risers/adapters?Clips and hooked pieces of plastic. Some of them are easy to break if you are not careful. The adapter is essentially a riser that clips into place and then the speaker will screw into that. There are no holes in the deck to screw down the rear speakers.
I used some for an 8th, but they needed some modification.Thanks. So did you make your own risers/adapters?
I need to go start checking for photos on what it looks like back there.
Got any pics?I used some for an 8th, but they needed some modification.
Plenty. I originally intended to do a DIY.Got any pics?
If you want to start the DIY with what you have I can post pictures to add to it later on when I do mine. I could try to take pictures to fill in any gaps etc. if need be.
Oh this would be so useful to me.I will see what I can do. I have a lot of pictures as it revolves around replacing the headunit and wiring to the rear speakers as well as for an amp and sub.
Oh this would be so useful to me.![]()
Nope. I can reserve the first post after your DIY and add photos there.You use Dropbox?
