JonnyRotten
Please don't jinx me.It will be interesting to see if the '14s do it. My '13 still does it. I'm going to call the dealer that Pete talks about to see if they have an update. I live in the same area.
I hope they are serious and not just blowing you off. Someone from Honda should sign up and monitor this site so they can keep on top of issues with their cars. There's certainly enough people on here that they would have a good sample size when things do come up. It's not just one person having a lot of these issues so the people at Honda need to pay attention.I spoke with dealer that @Pir8pete suggested in his post. They were familiar with the issue and said that they are working with Honda to identify the issue. He didn't know when they would have a solution. I told him that I'd call once a month to get updates. Maybe if I bug him enough he'll bug Honda......or just stop returning my calls.....
Thanks for doing some troubleshooting. Please report back with what the tech says or does.So I know this is a old thread but I have purchased a 13 civic si coupe with navi and having this issue. My issues are the door lock and unlock pops from diver and pass door switch. Took it in for warranty repair on this and they added a suppressor harness to the door lock plugs. It helped but still didn't cut out all the popping so I decided to troubleshoot it my self. I replaced the factory amp with an aftermarket amp hoping it was inside the factory amp. All that did was amplify the pop to make it much louder. I then noticed my pass side window from driver or pass switch caused it to pop as well. So I work in a car audio install bay so I grab a cheap radio and wired it into the car and all of the popping was stopped. Its something inside the factory headunit causing the issue. My car is going into the dealer tomorrow for them to troubleshoot yet again. I realize this is happening to people with nav and with out nav but from my research its all the cars that have a factory amp. Basically the factory amplified cars put out a low level input into the amp and high level out of the amp. Its not the cars at all. Its the headunit. Ill update and see what Honda has to say about the situation. The part I love is the tech I spoke with told me that he has never seen a car he cant fix. I believe he has met his match!!
I'm tempted to buy this noise filter harness, and maybe *revise* the filter circuit to see if I can do a better job.
If your tempted it sounds like back feed. Changing the grounding point of the head unit could work but that's really the only idea I have.
I have been experiencing the same issue from day one. I actually took the master tech , service advisory and manager to test this popping / clicking noise out on other vehicles. We tested both navi and none navi unit si coupes and sedans. What we found is that cars that have the Navi 2013 models would have a more pronounced noise compared to non navi units. I have been through three different dealers and will be going to a fourth shortly. I have own the car for 2 plus years and Honda still doesn't have a real fix. I am happy with the car other then that. Hopefully this is some helpful info
