DIY 2012+ Civic OEM Halogen Projector Headlights
Important Notes:
--Bumper Removal--
Important Notes:
- This article covers the installation of a set of Honda factory projectors (OEM) that come standard on Australian- and Asian-market Civics.
- These OEM projectors come with two unique harnesses: one for the parking lights and one for the turn signals. Honda's US headlights only have turn signals.
- If your headlights did not come with a plug-and-play harness, there are steps included here that show you how to create one. Creating this harness will avoid having to tamper with your vehicle's existing harness.
- Click on any of the pictures to see them in a higher resolution.
- Honda OEM halogen projector headlights
- Ratchet with 10mm socket and 10-inch or longer socket extender
- 5mm Allen (Hex) wrench
- Phillips screwdriver
- Clip puller
- Shop towels
- 12V 28/8W sockets (Honda part 33303-TR0-A01, quantity of 2)
- Self-adjusting wire stripper
- Wire cutters
- 20 gauge GXL automotive copper wire
(GXL wire is highly recommended as it is rated to withstand the heat of the engine bay) - Dielectric grease
- 3/8-inch split cable tubing/loom (7 feet or more in length)
- Electrical tape
--Bumper Removal--
- Remove the screws (A), the bolts (B), and the clips (C, D) securing the front bumper (E).
Screws at (A) require a Phillips screwdriver.
Bolts at (B) require a 5mm Allen wrench.
Clips at (C, D) can be removed with a clip remover.
NOTE: If you have a Coupe, one of the screws at (A) does not exist (see graphic below).
- Pull out the front bumper from the side spacer.Repeat this step on the opposite side.
- Pull out both sides of the front bumper (A) from the upper beam (B).
- Remove the front bumper.
Place the bumper on top of shop towels to reduce any chance of scratching the underside.
amazing
