2012 Taffeta White Coupe: Pro-Kit // 20 mm spacers
Looks very nice. Did you use any specific brand spacer?
I decided that the name brand spacers are way overpriced. I mean, its basically just a piece of machined aluminum with some studs pressed in. I went with a no-name brand found on eBay by searching 5x114.3 12x1.5 64.1
$59 shipped for a pair, and he even sent them 2 day express from CA all the way to FL. couldn't be happier. quality seems good and they fit both the hub and the wheel perfectly.
looks nice man! welcome
totally understand... I was just curious, as others have asked about various brands etc. :thumb:
I have a similar drop (I'm on H&R springs) and I'm really liking the look of how flush/even yours sits with the fenders. It fills the fender wells better without having to lower the car further. Do you have a camber kit in the rear? I would like to attain a similar look but I'm not using a camber kit.
thanks guys :)
yes, a rear camber kit was needed in order to obtain the necessary flushness :P
even with the mild drop of the pro-kit, it was around -2.3 to -2.5 degrees of rear camber which was too much for me. although not necessary, I also installed front camber bolts just to be able to have full adjustability on all 4 corners.
Oh gotcha. I figured a camber kit was used since the rears were so perfectly aligned with the fenders lol. Thanks for clarifying.
