kgf3076
Old, rude, and grumpy ex-track junkie.
- 408
- 198
- Vehicle Model
- Civic Si (Daily Driver) - '08 S2000 (Big-boy toy)
- Body Style
- Coupe (Civic), CR (S2000)
Straight from Honda.
Caster
USA and Canada Models:
Caster angle:
Non-Si: 5 degrees 19' +/- 30'
Si (Non 18" wheel): 5 degrees 22' +/- 30'
Si (18" wheels): 5 degrees 15' +/- 30'
Camber
Camber angle:
Non-Si:
Front: 0 degrees 00' +/- 30'
Rear: -0 degrees 45' +/- 45'
Si (Non 18" wheel):
Front: -0 degrees 04' +/- 30'
Rear: -0 degrees 52' +/-45'
Si (18" wheel):
Front: -0 degrees 18' +/-45
Rear: -0 degrees 45' +/-45'
(Maximum difference between front right and left side: 0 degrees 45')
Toe-in:
Rear Toe-in: 2mm +2/-1mm (0.08 +0.08/-0.04 inches)
Front Toe-in: 0 +/-2mm (0 +/- 0.08 in)
(I take no responsibility for these, I just copied them straight from the alignment spec sheet from Momma Honda. This is the first alignment information I've seen regarding 2014 models)
Caster
Caster angle:
Camber
Camber angle:
Non-Si:
Si (Non 18" wheel):
Si (18" wheel):
Toe-in:
