I'm less than a 1000k from my 15000k service and want to change my AT fluid...... Are you saying I should drain and refill with new fluid 4 times(after driving in between each D/F?).Quite the miles in a year man! wow! Drain and fill! 3 bottles I believe. Make sure to get a new crush washer for the bolt if you can. I have reused mine a couple times and it seems to seal fine though.
If you want to change out most of the fluid since you are only changing the fluid in the converter, make sure to take the car for a short drive before you do a second drain and fill. The dealership will just put the plug back in and rev it a few times in neutral. A short drive is much better to cycle the fluid. 3-4 drain and fills will cycle almost all of the fluid. If it's been a while do 2 cycles. I find that my trans likes the fresh fluid a lot.
I try to hit a D/F every 15k. Im ridiculous.
do 1 drain, then fill, and be done with it.I'm less than a 1000k from my 15000k service and want to change my AT fluid...... Are you saying I should drain and refill with new fluid 4 times(after driving in between each D/F?).
