Camber Kit
Danny Hsu
19
Anybody know if the Eibach front camber kit for the 2013 coupe Si will fit a 2013 coupe EX?
@Danny Hsu
NO, they are not the same. If Eibach lists the part as fitting both models you are safe. If they don't there is probably a difference. It is possible that the bolt size is different at the bottom of the front strut. Buy the correct camber bolts if that is what you are after. Ingalls and several others make camber bolts that fit.
Be careful as the knuckle size in front was different on the 8th gen between the Si and non-Si versions. Mostly due to the different brake caliper and rotor sizing. The front strut will be slightly different at the bottom.
Part numbers are different. Si parts will not always fit non si models.
2013 Si coupe front strut part #
51611-TS9-B01 SHOCK ABSORBER UNIT, R. FR.
2013 EX Coupe front strut part #
51611-TS8-B02 SHOCK ABSORBER UNIT, R. FR.
If you have a non-si stick with parts labeled as such. Some things are very very close. I would hate for you to purchase something and then it just barely doesn't fit or line up.
DIRECT FROM EIBACH/INGALLS:
For 2012 Civic, Si uses # 81280.
Non-Si uses # 81260.
Yes, it does designate the trim level. Si or non Si.
The TS# and the B0"x" are different.
2013 LX - 51611-TS8-B02 SHOCK ABSORBER UNIT, R. FR.
Non SI and Si are different. It's the end of the front strut where it connects to the knuckle and the lower arm. The bolt sizes are different. Ingalls/Eibach make note of this and have different part numbers for the camber bolt. I believe @AlienPrime had difficulty with the part number to fit the HFP struts as well.
@Danny Hsu
I've used the application guide on SPC though..it says I should run a 16mm camber bolt for 2013 non-si (81280k). I ran an application guide on Eibach's site for the 2013 non-si, they didn't list any camber kits available, so I tried the 2013 si models and they have one under the same model number (81280k). Also, the product description says 16mm
http://performance-suspension.eibach.com/performance_suspension/buy_online
I have a 2013 non-si btw..
