Flashpro maf and map
red13devil
16
Oklahoma
Civic si
Has any of u guys encounter this problem on your flash pro, I had a 2013 civic si and runing the flashpro beta stock map. After I load the map into my car it already using lambda (maf)so I want to tune it with the map instead of maf that way I can see my high fuel and low fuel, so I switch it to map but with map my car idle little rough not normal like when it was on maf.
wat
MAF is auto MAP is manual, you'll need to tune (change each and every block to perfection) in combination with other fueling options. GL there buddy, just use MAF
Thanks, so this mean I had to tune part throttle too rite, I though hondata make it where it runs at 14.7 afr and I don't have to mess with it but i guess not :(
yes you need to tune and no sir to hondata
