Fuse? HELP!
TheSlowAndTheSerious
1,356
New Jersey
Rewired my fog lights to my corner lights on Saturday. Worked completely fine till today. Corner lights, tail lights, and license plate stopped working. My turn signals (front and back) work fine, along with my reverse and brake lights. Can this be a fuse? If so which fuse is it?
Well fuse #34 was the culprit. It's a 7.5 I threw a 15 on now. Hopefully it doesn't blow this one
Edit: I'm going to switch it for a 10 amp fuse just to be on the safe side, or will I still be at risk of burning a wire?
What you need to do is put the right size on, or you could fink something up.
It blow for a reason, and that needs to be addressed.
I agree with monk, if you're blowin fuses, that usually indicates a short somewhere, which should be addressed immediately imo. If you just get a bigger amp fuse, then you could risk wire burn. I once had a friend in a situation such as this and he put a bigger amp fuse in against my advice, three days later while we were just standing next to his car, thick white smoke began to billow out from under his hood and a wire had actually caught his hood insulation on fire.
Just sayin, I have seen this happen more than once, and I would hate to see another horror story come from a fellow 9th, so better safe than sorry imo
Maybe just hard wire the car and bypass the fuses all together?
You should be fine with a 15. No worries. I have a 20 on mine.
he isn't running it the same way you are pauly.
He is sourcing power from corner lights to LED. the one you have is wired to battery and uses control from corners for switching am i right?
The corner lights are like #20awg and definitely too small to carry 10A+ to fogs inrush...
FOR REFERENCE SAKE:
Honda OEM safety put 28w corner bulbs in each corner.
28w/12v = 2.3A
Thats 2.3A on a #20 wire. Not the potential 10A+ you're using on inrush current
