I recently switched from a 2012 Si Sedan to a 2014 Si Coupe so I no longer have any use for the LED Tail Lights I purchased for the Sedan. I purchased them in March 2013 and have plasti-dip smoke with glossifier on the signal and reverse lights portion. Looking for $100 for the pair.
Things to note:
1) They cause static over the FM radio on weaker stations when the brakes are applied. I'm not sure how to correct this, but got used to it after some time. The problem only occurs on FM and only on weak stations (does not affect AM, Bluetooth handsfree, CD, or USB audio).
2) The plasti-dip does absorb rain water so it will appear spotted, when wet for an extended period of time. This disappears when it dries. Also, the plastidip can be removed.
You can view my build thread to see them installed and functioning (http://9thcivic.com/forum/threads/blimpcitys-9th.5398/page-2).
Things to note:
