Light problem
audio cuts out for me on the vid? One HID isn't working I'm guessing? Swap the bulb from the working side to the non-working side. Does the working bulb light up on the side that isn't working in the video? Does the bulb that isn't lighting up light up on the side that IS working? You can at least try to see if it's a bulb issue, a ballast issue, a grounding issue etc by seeing if the bulb is the culprit first. If this isn't the issue, can you describe what's going on in the vid?
Sorry for the audio cut off but yeah it was a ballast I switched it out and now I got both lights on ImageUploadedByTapatalk1411010061.815066.jpg
I've got to let the right burn 2 days and turn off the other one for 2 days so the color difference balances out now [emoji24] but thanks, you guys are very rapid in helping others in need [emoji16]
