NEED HELP GUYS!!!
Fg4_PreCiSe
New Member
4
2
whats going on guys so yesterday my COB LED STRIP came in the mail from hong kong and i was excited to slap it onto my license plate but when i was connecting something went wrong and now my front turn signals, my brake lights, and my rear license plate bulb does not turn on when i switch my lights to either auto, etc. the interior lights do work, when i switch my signals they do flicker, and when i press my brakes they do turn on but they just dont stay on when i switch my lights on, CAN SOMEONE PLEASE HELP !!!!!! all my lights are LED/HID never ever delt w this issue please someone HELP!!
Everything worked fine prior to the license plate led? If you put the oem bulb back into the license plate does everything go back to normal?
Some LEDs and LED strips are polar and only work one direction. Either try putting the stock bulb back in and see if everything works again or flip the connection around on the LED strip and see if that helps.
It sounds like a fuse. I had a similar problem with my ole corolla when i was putting in a new tail light harness. My license plate light, Tails, and signals went out, but I was still able to use my blinkers.
Check your fuses. good luck:)
