Need some advice..
OffTheWall
119
13
Virginia
Civic si
I got a new set of rims and I'm not sure I love the fitment. They don't "tuck" as much as I prefer. Any advice on how to fix it or what specs I should go with to achieve the look I want. I'm lowered on sport lines. Rims are 17x9 +22.
Thanks. Does anyone happen to know the specs of the stock wheels?
215/45 R 17
should be 45mm offset on stocks
If you want a flush look then your prob looking at a 30-35 offset.
Yup. Offset is very low. If you want to try and tuck some of the tire you're going to need to run a lot of neg camber. Like -5 or -6 degrees. That's a lot of tire wear too.
If you do some fender work, rolling/pulling/shaving, you can get away with a bit less camber but that offset is whats killing you. What wheels are they?
They are STR 520's. I got em for a steal. Couldn't pass it up. I'll look for some other wheels I guess. Not really looking to do fender work. At minimum I'll roll but not looking to pull them.
