NoMoreNissans
Is it normal for the reverse gear in a manual 2013 LX to be quite noisy? It's pretty whiny, kind of a winding noise, and I just wasnt sure if that was to be expected with these cars. The other gears are dead quiet
They burn oil. Actually, they drink oil like gas. My last maxima had 95000km on it and I had to add 5litres of oil to the motor in a short time of 2 months. Nissan knows about the issue and does nothingAnd what's wrong with Nissans BTW?
That's what I thought, good to hear it's normal. My gf pointed it out and I was like "all reverse gears do that"... then I was curious if it was actually true^ reverse gears are straight cut, so you will get a whine. It's normal.
Wow that's not very good. I knew they have their quirks but that's crazy. Is it a Maxima thing? Eitherway you should have no such issues with a Honda. There were some oil consumption issues but they are a defect that they fix if it occurs.They burn oil. Actually, they drink oil like gas. My last maxima had 95000km on it and I had to add 5litres of oil to the motor in a short time of 2 months. Nissan knows about the issue and does nothing
Depends how noisy but in general Hondas have noisy reverse gears. It has to do with the way they're cut.
If just hear them chugging along is fine. Try another one if you can and see if normal but they are noisy. The '12 Si you can hear all the gears but I actually like that![]()
Hmmm. Lemme guess...2001-2004 Maxima with the VQ35DE. That motor drinks. Plus, that seemed to be a bad group of years. The QE25 and VQ35 were plagued with oil consumption problems, primarily associate with the power valve screws. I once had a '03 Pathfinder. It drank oil at 1.5L/1000 miles. It burned catalytic converters. It lost it's power valve screws, which wrecked the piston rings and fouled the cats. Then it lost the butterfly valve itself and now it's in a junkyard.
That is insane. I always stayed away from them but I do love their sporty ones.
