Swapping Rear Stabilizer Bars Between Si and Non-Si
spdandpwr
148
NY / CT
Is this possible? I saw that putting an Si Stabilizer bar (RSB) on non-si 8th gens worked, just curious if that works on the 9ths or is there a difference between the models.
Thanks!
24mm front /19mm rear
same part # for r18 or si.
4087.320 front and rear
4087.310 front only
if there isn't a difference between them dimensionally, i.e. they can be swapped, then I know honda didn't go out of their way to change design in the ilx, just thickness.
