>> The ONLY Road-Legal LED Replacement bulb <<
XenonDepot
329
The FIRST Road-Legal LED replacement bulbs - Available in: 1156, 1157, 3157, 7440, and 7443!
Unsure of which bulb to get?
- Check out our Lamp Replacement Guide for detailed bulb information by vehicle.
Available in: 1156, 1157, 3157, 7440, and 7443!!
Philips 1156 LED bulb - Road Legal
Philips 1157 LED Bulb - Road Legal
Philips 3157 LED bulb - Road Legal
Philips 7440 LED Bulb - Road Legal
Philips 7443 LED bulb - Road Legal
Interesting... what makes them "road legal" just out of curiosity.
The light pattern. Philips would not release these bulbs in North America without having them tested. They are too big of a target for NHTSA, DOT, etc..
Just got some pictures of the Philips 7443 LED bulb installed in a Lexus GS:
Stock 7443 bulb:
80-80_img_3717_d7949d436fd5a1d013c1e090c299d3dce2af12ee_f9ef4f78b113af5d3b32f2c152fb6aa4685bdc6b.jpg
Philips LED bulb:
80-80_img_3715_0921b426a49c2f83f7418872d6935b778c3f94e3_46ea1354ecad600c3965029bf52160b8f9f4f8eb.jpg
80-80_img_3745_ca9411b746cacf5acbe473895a076028370d237c_caef1f5735b827f0f5baea017ab969a66f8994d1.jpg
80-80_img_3747_df5ff87acfbaaee78e595c062218b9a3d3dde353_459a823f4afb987ea228e20c39f0cf61b6798b7e.jpg
80-80_img_3715_0921b426a49c2f83f7418872d6935b778c3f94e3_73f3dce024099dd234a390db4fb4cbb3e9645063.jpg
80-80_img_3744_8690882d2846d467cbd96f9982a6ef206906d480_25bd8d16323cc4c502278258389a26d8d0478471.jpg
Notice how well they distribute the lights? Philips designed these LED replacement bulbs to maximize the use of the reflector bowl - just like it’s designed to be used!
Make sure to check out easy to use HID/LED/bulb Lamp Replacement Guide to see what bulbs your vehicle uses.
Steve
Is it like a glass dome on the top? Plastic? Reminds me of the look of a standard hid projector lens.
Correct! However, if you install them in a turn signal application then you would need a load resistor to simulate a load.
What application are you thinking of installing the bulbs in? What year is your vehicle?
Steve
2014 civic lx sedan, wanted to replace the inner rear parking light(doesn't light up when the brakes hit), turn signals in the front, and the drl(high beams I guess technically)
thanks for the reply also!
