Top Gear finds 'world's most unstoppable vehicle'
iluvmycsx
Mr Csx
VIP Member
3,215
1,317
Acura Csx
It's the car Jeremy Clarkson may need if his wife is on the warpath over his alleged affair.
That's because this vehicle is about as indestructible as they come.
Tested on Top Gear by Clarkson's co-presenter Richard Hammond, the Marauder is a ten-ton military vehicle that the public can buy - if you have £300,000 spare.
To prove its credentials on the battlefield, Hammond conducted a series of tests to show just what it can do.
Most staggeringly of all, the presenter placed seven pounds of plastic explosive under the vehicle to see what damage it caused.
The answer was very little. In fact the car barely even had a scratch, with just a flat rear tire and damage to a piece of trim.
In contrast a Hummer - another military vehicle - was blown to pieces by the same amount of explosive during the test.
Hammond also blasted through brick walls in Johannesburg without even slowing, and showed a cheeky wheel-clamper who was boss by pulling his tow-truck.
He also turned a couple of parked cars into two piles of scrap metal and took a trip to a safari park to meet a couple of hungry lions.
Hammond was in Johannesburg because the car is South African built by the Paramount Group.
It is 21 feet long and 9 feet tall. Its engine produces 290 horsepower, with a top speed of 70mph.
With its military background the car has windows that are 9cm thick and cannot be opened - apart from a small porthole.
The windows are so rigid that they can withhold a rocket propelled grenade attack.
And with it being able to repel an RPG, the car is also kitted out for the warzone.
It can carry eight in the back - albeit in far from luxurious comfort - and also has storage facilities for its own weapons.
Should also mention that you need to pass a background check to make sure your a bad guy... I just saw the episode this morning...
that is essentially a tank with rubber wheels. That thing has to weight a ridiculous amount of weight. With 290hp.... it begs the question
I had to look up the humvee that the military uses, and wikipedia claims a weight of 5200-5900lbs
If that literally means this thing weights 10 tons... you're talking 20k pounds?!
5200 - 5900 seems too light. My extra cab Superduty pickup weighs that much, and I'm sure that plastic explosives would shred it like a paper bag.
Well, I looked further, and found this:
The M1114 Up-Armored HMMWV / Curb Weight: 9,800 lb
So the up-armored version is still roughly half the weight?
Sad part is that even the armored humvee is still weak compared to The Marauder
The Marauder has a heavy, thick, wedge-shaped chunk of armor on its underbelly, which is designed to resist a blast from underneath.
I would not be surprised to find out that it is actually pushing 20,000 pounds.
