Tuning issues please help
nothing needs done with a clutch in flashpro unless you installed a lightweight flywheel.
Well is a act flywheel so imagine is more lightweight than stuck! So I took misfire check mark off and it is different!!!
yeah, so you have to disable it, or the car will go into limp mode. Hondata has mentioned that lightweight flywheels will throw codes. You don't have to worry about it since you have flashpro. Others have done aftermarket clutch/flywheel swaps without having hondata. Then it's a problem.
Well in my case I did not see any codes, but the car rubbed like hold up like the WHP was not there once I disabled misfire boom it feels awesome
