Any DIY articles on here to remove/ reinstall the valve cover?
Jan 6, 2016 #1 FG4 Pjay Well-Known Member 222 80 Guam Vehicle Model Civic Si Body Style Coupe Any DIY articles on here to remove/ reinstall the valve cover?
Jan 6, 2016 Staff #2 webby Administrator Admin Toys For Tots 56,243 24,027 haven't seen a 9th gen diy, but the 8th gen version would be almost identical http://www.8thcivic.com/forums/diy-honda-civic-engine/146014-diy-valve-cover-removal.html
Jan 6, 2016 #3 squiggy Cartographer VIP Member 11,331 6,755 Michiana Vehicle Model Toyota MR2 Spyder Body Style Convertible I am not positive, but you may want to check with @323 on whether or not you can remove the rear bolts without removing the cowl and plate under the cowl.
Jan 6, 2016 #4 Flightmaster127 Supporting Member VIP Member 3,628 2,379 Delaware Vehicle Model Civic Si Body Style Sedan You may want to pick up some Honda bond or other rtv. They generally call for a small application in some areas so there are I leaks.
