Wheel help
Ali Ahmed
New Member
1
0
Hey all new here,
sorry if I’m posting in the wrong spot. I have a 2013 civic si sedan. I’m looking to get a set of winter tires and steelies that were on a 2007 Camry. Same bolt pattern BUT my bore is 64.1 the Camry steelies are 60.1... will they still work or should l look for something else? Thanks
You need something that is 64.1 or larger. If you go larger, you’ll need to buy some hub centric rings. The rings will gap from 64.1 up to whatever size bore the bigger wheels are. They’re very cheap and come in a billion sizes to adapt to tons of different wheel configurations.
