EyeCandyXposure
Active Member
- 14
- 0
What's difference between drilled and slotted Brembo brakes?
Thanks
Thanks
Where do you find those?Dc5 type r brembos bolt on directly with s2000 rotors. Just need wheels to clear them.
Whaaaaaat? Well I know what my next mod is then. Any issues with pedal feel or anything like that?Dc5 type r brembos bolt on directly with s2000 rotors. Just need wheels to clear them.
Do you think stock wheels would fit? If not, what size or offset would you need?I never got around to even feeling the pedal because i just test fitted them on there, and my wheels didnt clear. so i left the stock brakes on.
ok thanksNo way in hell stock wheels would fit. You'd need like a 25mm spacer. Maybe more
It's not so much offset as it is spoke design. But the most popular options are usually the under 9" wide rpf1. So like the 8-8.5" versions. Because the spokes bubble out instead of concave in.
I don't know for sure which wheels fit. Best bet is to go on 8th civic and see what other guys have done with brembo setups.
ok thanks
my plan was to go get big brakes before big power, because you know...you have to be able to stop lol
And don't forget stainless lines.You'd be surprised what a good set of pads and rotors can do. The big brakes more or less just prevent brake fade.
even with just one piston?You'd be surprised what a good set of pads and rotors can do. The big brakes more or less just prevent brake fade.
