6. Using automotive grade wiring (18 gauge), connect the yellow wire to a positive 12 volt constant (un-switched) source either on the vehicle or in the fuse box.
7. Using automotive grade wiring (18 gauge); connect the red wire to a positive 12 volt ignition (switched) source. It may be connected to the fuse panel, an accessory wire, or any positive 12 volt source that turns on and off with the ignition.
Does anyone know which fuses in the fusebox are switched and unswitched? I don't have a multimeter and it would make my life 10x easier!
