All 9th civics regardless of trim have the same +45 offset on whatever factory wheels they were equipped with. Stock ride height should also keep you from having any rubbing issues if you do run a 20mm spacer.Most threads are about si so I am not sure if 20mm is right for me.
Also, my ride is at stock height and I plan on keeping it like that.
