Tony-si
i thought it would but it only worked bluetooth. i thought it would but NOPE.
but its an ipad airStep 2. Open pandora from your .... phone
but if its connected to the usb then how does it send info to the dash then? i have a cell/wifi but i use my andriod as a hot spot.An iPad isn't a phone?
I don't understand your question. The USB talks to the radio system. Plug your phone in and start playing music you have saved to it and it acts like an iPod. Turn on pandora and it will stream pandora.
i have to agree with you. booo honda should make a firmware update for us lolI believe the issue is that the radio doesn't support the iPad. There are only certain devices the radio will recognize.
also was thinking because its an Air might support an ipad but one generation lower.I believe the issue is that the radio doesn't support the iPad. There are only certain devices the radio will recognize.
the latest iOs 10.3.3what software version is the IPad? is any other devices work with the USB Plug-in or will it charge?
