PainlessCandy
Had a weird issue on my way home from work just now. Started the car, went to pull out of the parking garage, and the tachometer started going crazy. First it fluctuated between 4900 and 5200 RPMs, then it would fly all over the place from past the red line to zero. It did not seem to react to the actual RPM changes and when the needle was in the appropriate range the VTEC indicator lights would light up. The motor ran fine, it did not act abnormally while running. I turned the car off and back on and the problem disappeared. Has anyone else experienced this before?
