Bought a civic with no key fob
Discussion in '9th Generation Civic General Discussion' started by Silver8th, Jan 17, 2018.
  1. Silver8th
    Silver8th Well-Known Member
    11
    Hey y'all so I just bought a 13 Civic Si and it didn't come with any key fobs it only has the spare key. Any suggestions? Has anyone had there car rechipped or re-keyed. Would it be a whole new immobilizer?
  2. webby
    • 2019 Toys For Tots
    webby Administrator
    50,266
    Like the only thing you have is a gray valet key? Where did you buy the car, and why didn't they have "keys" for it? I'd be worried that someone has the real keys and could just swing by your place of work/home and drive away with your car.
    [​IMG]
    Silver8th likes this.
  3. webby
    webby Administrator
    50,266
    you can buy replacement keys though. Programming is a simple process -
    (I should note that this would still be the process using the gray valet key, and then buying a fob like he has in the video. If you want the actual fob in the key itself, like the normal factory key, you'll have to get it programmed at a dealership to get the immobilizer to work. You can buy a blank key/keyfob for the car, but then the immobilizer will need programmed at a dealership, and that can run 75-150 dollars or so depending on the dealership)
    View: https://www.youtube.com/watch?v=EQ49iKWbLXo
  4. webby
    webby Administrator
    50,266
  5. Silver8th
    11
    Ok so i got the car for a unbelievable low price of 6k steering wheel airbag is missing and pass side curtain air bag popped as well car had front end damage. It was picked up at an auction buy a repair shop they fixed the front end damage but not the airbags and the car has no keys except for the valet key. I just talked to the dealership and she quoted me around $200 her for two keys fob and a reprogram. So that seems very reasonable.
  6. Silver8th
    11
    50 per key fob
    5 each to cut them
    65 reprogam for both keys.
  7. Silver8th
    11
    Like this car alot.
    ron v and webby like this.
  8. webby
    webby Administrator
    50,266
    Glad to hear they are getting you keys
  9. ThisIsFRSH
    ThisIsFRSH Well-Known Member
    38
    Tampa, FL
    Vehicle Model:
    Civic LX
    Body Style:
    If you go to the dealer they should be able to give you a replacement. I remember for my 8th it was around $55.
  10. sebastian-mp
    sebastian-mp Well-Known Member
    9
    Hi!
    I just got a new key fob for my 2014 civic lx and after trying multiple times I still can’t program it. I move my original key from off to on and click the lock button and repeat 4 times but I can’t make the lock system cycle and program the new key fob.
    Any advice? Is the process different for a 2014 civic lx? Thanks!
  11. ThisIsFRSH
    38
    Tampa, FL
    Vehicle Model:
    Civic LX
    Body Style:
    Last time I checked, you can go to a dealership with the title and they’ll set you up with a new one for $50-$60.
  12. webby
    webby Administrator
    50,266
    Doesn't your key have the lock/unlock on the key itself like the picture below? You say you're using the original key, but purchased a new fob?
    [​IMG]
  13. sebastian-mp
    9
    Yes that is the key that I have. I bought a flip key that is supposed to come with the civic in japan so i was trying to set that one up.
  14. webby
    webby Administrator
    50,266
    Flip keys are an entirely different ball of wax. There wasn’t even a 9th generation civic in japan (so the seller lied, but anyway). Take a look through this thread. Just swapping your key guts over isn’t enough to get that key to work or even start the car.
    http://9thcivic.com/forum/threads/flip-key-thread-for-9th-gen.7863/
  15. sebastian-mp
    9
    That’s unfortunate. This is the key that I bought: https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/131920555981
    It look the same size and the fob has the same layout as my original key
  16. sebastian-mp
    9
    Just an update:
    I was able to get my flip key cut, get the transponder programed, and get the key fob programed.
    I found a locksmith who was able to do all this for $90.
    The result is great. No hacking or gutting out an old key. Everything works perfectly so far.
    webby likes this.
Share This Page
