- 55,560
- 23,825
You will gain negative camber in the rear of the car when you lower it. To get the car back to within factory spec, or have the ability to adjust your rear, you need those camber arms. Most users haven't done the fronts, but you can get camber bolts if you want to adjust the front. Some run negative in the front to allow for much wider wheels and tires.Webby what is the use of this rear camber kit?
