Issues with fog lights
Discussion in 'Mechanical Problems & Technical Chat' started by Brian Carter Jr, Nov 23, 2018.
  1. Brian Carter Jr
    Brian Carter Jr Member
    22
    I was looking at my fuse panel diagram and what if I connected to the fog light fuse itself? it says 20A is for fog lights.
  2. Cman46290
    Cman46290 Active Member
    47
    Worth a try I would say. Did you see a fuse in the ip fuse block for it? Surprising it would have that if the car didn't come stock with fogs
  3. Brian Carter Jr
    22
    I don’t have the model that comes with it, but I just took these aftermarket ones out and will be purchasing oem ones shortly
  4. Brian Carter Jr
    22
    So I uninstalled the fog lights and found the issue, the cheap brand I bought from the unit wasn’t sealed, the connectors were rusted as well as a large amount of water came out of the housing.
  5. Cman46290
    47
    I figured it would be something like that. Glad you were able to figure it out. OEM is the way to go.
  6. Brian Carter Jr
    22
    Yeah, I’m going oem that plug directly into the harness
  7. webby
    • 2018 Toys For Tots
    webby Administrator
    49,587
    You could always use clear silicone and seal the ones you have. I don't know how bad they are
  8. webby
    webby Administrator
    49,587
    Brian Carter Jr likes this.
Share This Page
