Maintenance info
Discussion in '9th Generation Civic General Discussion' started by K24RippiniT, Sep 13, 2017.
  1. K24RippiniT
    K24RippiniT Well-Known Member
    10
    Hi all. I just bought a 2012 si sedan last week and was wondering what these mean. Do I need to change/replace them? IMG_20170913_004637.jpg IMG_20170913_004634.jpg
  2. TF_FB6
    TF_FB6 Well-Known Member
    81
    York, PA
    Vehicle Model:
    Honda Civic SI
    Body Style:
    Yes you need to change your oil and oil filter, Rotate your tires and change your trans fluid
    K24RippiniT likes this.
  3. K24RippiniT
    10
    Why does it show 100% if I need to change the oil?
  4. TF_FB6
    81
    York, PA
    Vehicle Model:
    Honda Civic SI
    Body Style:
    didn't pay attention to that, but if your oil looks clean then id just reset it, someone probably did the oil change early or is on a different schedule then the car system is, its mainly just a maintenance reminder for preventive that needs done.
  5. Sarcras
    Sarcras Well-Known Member
    1,133
    North Dakota
    Vehicle Model:
    Body Style:
    FB6
    I would check your oil and tire tread depth. It could be that it still needs the work done and someone accidently reset the oil life indicator. If the oil looks like it needs changed and you have lower tread depth on the front then best guess the transmission fluid does still need changing.
    Also, how many miles are on it?
  6. freggie
    freggie Well-Known Member
    111
    Hesperia, California
    It is telling you what needs to be done at next oil change. It is showing two things: oil life, and what needs to be done at the next oil change. When the oil life gets to 30% or lower those are the items you are going to do. It is giving you a heads up so you can buy your trans fluid when you buy the oil and filter.
    If you reset the maint. minder I bet the trans fluid will not appear
    here is a helpful linky
  7. homegrown
    homegrown Well-Known Member
    136
    Vehicle Model:
    Body Style:
    FB6 Sedan
    PSA: When you change your oil and/or rotate your tires, don’t forget to check your tire pressure, including the spare! It’s really easy to neglect the spare tire. You don’t want to get stuck with a flat and your spare tire is low also. Spare tire pressure is usually 60PSI.
  8. Verzerrung
    Verzerrung Well-Known Member
    150
    Yucaipa, CA
    Vehicle Model:
    Civic
    Body Style:
    I got my 2012 R18ZI about a year and a half ago with 76K miles and it currently sits at 113K miles. I change my oil and filter every 3k - 5k miles and recently got brand new tires, filled the brake fluid and brand new brakes all around. I have no codes popping up, but how often should the coolant and and transmission fluid be changed? I know I'm due for spark plugs, I'll likely be getting the NKG Iridium. (Says they don't fit my car?)
  9. Sarcras
    1,133
    North Dakota
    Vehicle Model:
    Body Style:
    FB6
    It should say in your manual for the coolant and tranny fluid. The NKG Iridium fits the Si so I wouldn't think the block would change so much that they wouldn't fit in the R18. May have to gap them though, not sure.
  10. Verzerrung
    150
    Yucaipa, CA
    Vehicle Model:
    Civic
    Body Style:
    Gap them?
  11. webby
    • 2019 Toys For Tots
    webby Administrator
    50,687
  12. Verzerrung
    150
    Yucaipa, CA
    Vehicle Model:
    Civic
    Body Style:
    Always wondered what those were for. Thanks, very helpful!
  13. Flightmaster127
    • Supporting Member
    Flightmaster127 Supporting Member
    3,589
    Delaware
    Vehicle Model:
    Body Style:
    Coolant i believe is around roughly 100k if i remember correctly, your manual will tell you for sure.
    manual Trans fluid is 30k intervals, but many people myself included change it more frequently, especially if you drive the car spiritedly or do any sort of track or autoX events with it. or are you automatic? I don't know the correct interval on that.
    either way use oem Honda fluid for both if you do decide to change them.
  14. ron v
    ron v The good, the bad, and the booty
    4,298
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Landscaper Truck
    I usually change my tranny every other oil change.
    Flightmaster127 likes this.
Share This Page
