DIY Resonator Delete (Si Sedan)
Discussion in 'Intake & Exhaust DIY' started by Smokeditty, Jun 28, 2012.
  1. Bartjo06
    Bartjo06 Well-Known Member
    247
    Old Town, ME
    Vehicle Model:
    Body Style:
    Did this on my coupe today, it's possible to do it without taking off the wheel/tire, just a tight squeeze when pulling things out.
    Nefertiti_Civi and spiders_wrath like this.
  2. squiggy
    • 2019 Toys For Tots
    squiggy Cartographer
    11,027
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    I did this last weekend and have noticed a whirring sound when slowing down. Kind of like blowing over the opening of a bottle. Except higher pitched. Not sure how much I like it. Definitely notice a bit of a better throttle response, though.
  3. Lazaro Ravelo
    Lazaro Ravelo Active Member
    29
    Miami, Florida
    Vehicle Model:
    Civic LX
    Body Style:
    pray you don't live in a flood zone in Miami like I do lol
  4. d_u_a_n_e
    d_u_a_n_e Well-Known Member
    135
    Nor Cal - 707 - Sonoma County
    Vehicle Model:
    Body Style:
    Very nice write up, will be giving this a try. Def looking for the throatier growl from the intake.
  5. boejoula
    boejoula Well-Known Member
    215
    Vehicle Model:
    Body Style:
    This is fine to do with the stock intake?
  6. webby
    webby Administrator
    50,861
    Yep, most do it that way. Some have k&n drop in filters that replace the oem filter. Either way it'll work.
  7. boejoula
    215
    Vehicle Model:
    Body Style:
    i plan for a CAI in the future. hoping Skunk2 makes one for our 9th
    d_u_a_n_e likes this.
  8. d_u_a_n_e
    135
    Vehicle Model:
    Body Style:
  9. boejoula
    215
    Vehicle Model:
    Body Style:
    I had read about the Rick Spec'd for the 8th and then I talked to him on 8th. He said they have one for the 9th coming soon. From what I've heard it puts up really good numbers on the 8th so that might be where I'm headed when it becomes avail
  10. Taffeta 12
    Taffeta 12 Well-Known Member
    466
    Antelope Valley
    Vehicle Model:
    Honda civic Si
    Body Style:
    Just finished. Just FYI you don't need to take the wheel off, just turn it all the way to the left. Took me 15 minutes. A little tight squeeze pulling everything out but nothing too bad. Nice little sound difference too. I don't think water is an issue unless your blasting through deep puddles a lot. And if your doing that well... You know :)
    Those retainer clips are kind of flimsy too, be careful. I broke one.
    K24Z7SiGuy likes this.
  11. Lee Marchand
    Lee Marchand Well-Known Member
    64
    Is there not a filter you can buy to put on the open piping by the wheel well? I know the plastic should work fine but better safe than sorry I guess.
  12. Bulkybear
    Bulkybear Well-Known Member
    1,665
    Easy as pie. Took me 1 hour. But if I ever need to do it again it definitely is a 15 to 30 minute job. Excellent diy. Thanks! :D
  13. HondaCivicSI12
    HondaCivicSI12 Active Member
    5
    Jacksonville, NC
    Vehicle Model:
    SI
    Body Style:
    To piggy back off of a prior question, Once the resonator is off do you or don't you have to disconnect the battery to and then let the car idle for 10 minutes to reset? Thanks in advance
  14. HondaCivicSI12
    5
    Jacksonville, NC
    Vehicle Model:
    SI
    Body Style:
    You probably could use one of those K&N mesh wraps to cover the opening to stop some excess debris. I'm gonna look more into this as well since I kind of feel the same way about having a huge hole exposed so close to the ground and wheel.
  15. Gorrila88_13si
    Gorrila88_13si Well-Known Member
    128
    great DIY thanks
  16. sthompson86
    sthompson86 Well-Known Member
    165
    Pearl, MS
    Vehicle Model:
    Civic si
    Body Style:
    Thanks for the DIY - Took me about an hour due to me being careful.
  17. mongoose221
    mongoose221 Well-Known Member
    406
    middletown, NY
    a side note: i installed my takeda momentum intake, and this res delete works great with that intake as well, basically a CAI with the conical filter/icebox up higher
  18. sthompson86
    165
    Pearl, MS
    Vehicle Model:
    Civic si
    Body Style:
    The Tekeda is the intake I am considering. Did it increase the throaty sound? I really like the throatiness of the res delete an increase would be nice. Not big on the full CAI vacuum sound.
  19. mongoose221
    406
    middletown, NY
    yesh, it's a SLIGHT CAI vacuum sound under throttle stabs, not much under WOT, and not that noticeable, only a very SLIGHT increase over the res delete, it's a good sounding intake.
    sthompson86 likes this.
  20. A Tuxedo Cat
    A Tuxedo Cat Well-Known Member
    53
    Massachusetts
    Vehicle Model:
    Body Style:
    Coupe FG4
    I'm still too nervous to do this. I never did it on my FA5 and just went with an SRI. Think I'm gona do the same on the new one. Living up in New England sucks sometimes.
Share This Page
