SiriMoto N1 FB6 - 2014 Sedan Si
Discussion in 'Build Threads' started by ruddyrid, May 2, 2019.
  1. ruddyrid
    ruddyrid Well-Known Member
    44
    The Whitehouse
    Vehicle Model:
    Body Style:
    It's probably long overdue, but finally starting a thread for the Pro Car Studio / SiriMoto Civic Si :)
    So let's jump right in to some of the more recent updates to this car:
    Car as it sat during the RBC Swap:
    Hasport Upper and Lower Torque Mounts (62a):
    I took apart the mounts to send them off to anodizing, along with a few other bits, to protect them from corrosion and start a bit of a color scheme I have planned.
    RBC Swap:
    - Settled on a KTuned coolant bypass/manifold adapter, as apposed to TracTuff. Upon initial install, the bypass was leaking and so I went ahead and drilled into the cylinder head to positively fasten the plate (instead of using the spring washer set-up).
    - Using a 70mm Throttle Body along with the SiriMoto Big Bore Throttle Body Adapter, Thermal Throttle Body Gaskets, Thermal Manifold Gasket and SiriMoto 550cc EV14 Fuel Injectors (as the car runs Flex Fuel).
    - Made an extension harness for the throttle body connector too, as the stock harness comes up short.
    Skunk2 Cold Air Intake:
    - Retrofitted an 8th Gen Si intake and ended up working well for me. I did not need the batter relocation bracket as I'm running a small motorcycle batter with my own bracket design (weighs about 4lbs).
    Battery Relocation:
    Skunk2 Composite Fuel Rail:
    - I was actually running this on the stock manifold as well and it fit decently. I found the included bolts to be 5mm too long, so I simply swapped out what they included with the fuel rail. Also, had to rotate the inlet tube a bit towards the back. Reason I went with this fuel rail is due to it's material construction and the fact that it has so many ports, since I am running both a mechanical fuel pressure gauge and a electronic pressure sensor gauge.
    SiriMoto Tow Strap:
    - Straight forward install, simply drilled a hole in the aluminum bumper beam and used the provided hardware to bolt it in place.
    bootyluvr, mySIck and webby like this.
  2. webby
    • 2019 Toys For Tots
    webby Administrator
    50,705
    very nice. Have you run it on the dyno to see what kind of power you're getting out of your e85 setup?
  3. mySIck
    mySIck Well-Known Member
    1,985
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Nice!!! I really needed that harnesses for the TB mine is on extremely tight.
  4. mySIck
    1,985
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    And I am digging that battery setup I wish I did that for my NA set up instead of relocating it to the back.
  5. ruddyrid
    44
    The Whitehouse
    Vehicle Model:
    Body Style:
    Not yet, it does feel nicer at wide open throttle even with just the base map though. Hopefully I can go to the dyno end of this month/early next.
    I had to buy a couple of the connectors to make my harness, so if you're interested I can whip one up since I have all the parts. Thanks though, I want to keep the car fairly simple and din't want to run the battery in the back. Took me maybe a total of 2 hours to design, then had it laser cut and bent.
    mySIck likes this.
  6. mySIck
    1,985
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I might have to hit you up on that offer sometime. I need to get a few other things for my suspension soon once my wife cools off about the money I spent the past couple months lol.
  7. mySIck
    1,985
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    @ruddyrid could you post up some of you suspension modifications when you get some time?
  8. ruddyrid
    44
    The Whitehouse
    Vehicle Model:
    Body Style:
    Sure, I don't have all the pics organized to post up right now, but here's a list of what it has:
    D2 Racing RS Coilovers
    Skunk2 Rear Camber Arms
    Ingalls Front Camber Bolts
    SiriMoto Phase2 Strut Bar (Front)
    SiriMoto Phase2 Trunk Brace
    SiriMoto Carbon Fiber Strut Bar (Rear)
    SiriMoto W-Brace
    SiriMoto Front and Rear Lower Tie Bars
    Progress 24mm Rear Sway Bar
    SiriMoto Spherical Sway Bar End Links (Rear)
    mySIck likes this.
  9. bootyluvr
    • Supporting Member
    bootyluvr Supporting Member
    18,068
    Baltimore, MD
    Vehicle Model:
    2015 Honda Accord EX-L V6
    Subscribed. Nice build :thumbsup:
    ruddyrid likes this.
  10. mySIck
    1,985
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I got the D2 RS too I was actually surprised how smooth they are I have about 30,000-35,000 miles on them now and still kicking it.
    I have looked into the Sirimoto Kits for a future buy and the Skunk2 control arm to bring my camber back into spec.
  11. ruddyrid
    44
    The Whitehouse
    Vehicle Model:
    Body Style:
    Awesome, yeah the coilovers on this car only have about 10k miles on them but have held up well too. Super comfy on the street, was surprised they would feel softer than stock and tighten up very well on the stiffer settings.
Share This Page
