Speaker wire
Discussion in 'Audio Setups & Aftermarket Head Units' started by GeoUCF14, Aug 28, 2017.
  1. GeoUCF14
    GeoUCF14 Well-Known Member
    11
    Hello,
    Those that wired in an aftermarket amplifier and kept the stock head unit; did you reuse the stock wiring harness speaker wires (now powered by the aftermarket amplifier), or did you run new speaker wires directly from the aftermarket amplifier to the speaker location (bypassing the original wiring/speaker harness)? Does anybody know what gauge the stock speaker wires are? The amplifier I have is JL Audio XD 700/5 (75watts x 4 + 300 x 1, all at RMS power).
    Thanks
  2. webby
    • 2019 Toys For Tots
    webby Administrator
    50,721
  3. freggie
    freggie Well-Known Member
    112
    Hesperia, California
    Most people would use the factory speaker wires and even installing new speakers, most people use the factory wiring.
  4. Marc Meyers
    Marc Meyers Well-Known Member
    48
    Ohio
    Vehicle Model:
    Body Style:
    EX
    I don't know for sure but, I thinks the stock speaker wire is less than 18 gauge, I ran new 16 gauge to all. I found going down the passenger side with all easiest. Be ware The bottom door piece has a hook modeled into the back end of it, I broke it. And the doors aren't easy.
  5. GeoUCF14
    11
    Thanks
  6. MaddogFo20
    MaddogFo20 New Member
    2
    I'm replacing my front door speakers on my 2013 honda civic coupe and the driver side wires I exposed after cutting wire harness off that hooked into speaker I had no issues with finding which was positive/ negative. My problem is on the passenger wires after I cut off wire harness for speaker are 2 different colors than the driver side. So I dont know how to find positive/ negative on passenger side. Any help would be appreciated
  7. webby
    webby Administrator
    50,721
    There are speaker wiring diagrams/colors in this thread that should help
    http://9thcivic.com/forum/threads/2012-civic-audio-wiring-guide-pinouts-for-factory-radio.5916/
Share This Page
