Strut or(and) Shock?
Discussion in 'Suspension And Brakes' started by zhongyang3, Mar 12, 2015.
  1. zhongyang3
    zhongyang3 Well-Known Member
    18
    Vehicle Model:
    Body Style:
    The dealership recommended that I replace the strut assembly because the nut at the top of my shock keeps slipping off, which means the threading is bad (I'm getting new sets tomorrow). If you look at the pics I took, you can tell that the bad side leans a bit and the good side is centered and the nut is all the way down. What could be causing this? And could my other suspension pieces be affected(ball joint, camber)? Would a replacement from a General retailer like AutoZone or Napa have decent replacement parts?
    Back story: I hit a pothole on the front passenger side.
    Good strut on top
    Bad on bottom
  2. squiggy
    • 2019 Toys For Tots
    squiggy Cartographer
    10,951
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Did you tell the dealership you hit a pothole?
  3. zhongyang3
    18
    Vehicle Model:
    Body Style:
    Yes. They wanted me to replace the strut assembly after the diagnostic which I hope means no other parts were damaged. Which leads me to wonder if a part from AutoZone is a decent replacement (I'm getting both sides and is on a budget).
  4. squiggy
    10,951
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    I don't see a need to get both sides if you only damaged one of them. You can get an OEM replacement online for about $100 if you look around. Or you could post on the forums that you are looking for a set. I'd imagine there are some people that still have theirs after putting coilovers on.
    If you are not able swap them out yourself, labor can get a bit pricey on struts.
  5. Nomar06
    Nomar06 Super Moderator
    7,418
    Charlotte, NC
    Vehicle Model:
    Fiesta ST (FiST)
    Body Style:
    hatch
    Check the For Sale section.....two member selling fronts and rears for $200 or less....
  6. chris_lx
    chris_lx Active Member
    26
    If i get coilovers would i need new struts? Cause i have lowering springs on right now and was told struts would b a good idea.
  7. squiggy
    10,951
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Coilovers are a strut spring combo.
  8. chris_lx
    26
    Gooootcha
  9. webby
    webby Administrator
    50,602
    It would replace your strut/shock/springs you have on the car currently.
  10. zhongyang3
    18
    Vehicle Model:
    Body Style:
    Thanks everyone. This is why it was rattling. The threading on my passenger shock is gone. And the mount is rounded out too. Got new ones coming. uploadfromtaptalk1426278950574.jpg
  11. zhongyang3
    18
    Vehicle Model:
    Body Style:
    I put the new mount on with two bolts on top to hold the bottom one down since the threading was still good up top.
    I want to confirm from another post that the 2011 shock mount works for 2012. Napa didn't have 9th gen so I got 8th gen one.
    webby likes this.
Share This Page
