siracergrl
I've gotten a couple people asking me where I got my yellow fog overlays so I figured I would share the template I made when I did mine. I drew mine by hand so please excuse the imperfections in shape. I promise you though, as long as you follow the directions I give, these will fit perfectly on your Civic.
Thanks to webby for helping me clean up the hand drawn overlay
Materials Needed:
Materials Needed:
- Soapy water in a spray bottle
- Scissors
- Vinyl Sheet (color of your choice)
- Exacto knife or razor blade
- Overlay Template
- Rubbing alcohol
- To get the proper size printout of this template, make sure in your print settings that it is being printed at 100% scale.
- Next you will want to cut out your overlay and place it on your vinyl sheet. Trace out your overlay and cut out with the exacto knife.
- Then you will want to clean the surface of your fog lights with some rubbing alcohol so that the vinyl sticks better and to remove any dirt/debris that may be on the fog lens.
- Next you will want to liberally spray the lens with the soapy water. (This will give you some play in the vinyl if you happen to mess up).
- Peel the backing to your overlay and place on the fog lens. The template has some excess to it but that is ok because it should slide under the black molding around the fog light. Once your overlay is in place use a small squeegee or piece of cardboard to get any remaining bubbles that may have formed.
- You could also turn your fog lights on in order to heat the lens and help the overlay stick on better once you are done.
