LSD is Si only in Canada at least.Do the non si models have a LSD? I was under the impression that was only on the Si's.
The Si does have VSA. If i remember tight, all cars sold in the USA are now required to have some sort of stability control system.As far as I know the Si does not have vsa, that's why I thought you were asking about the other models. The LSD is not electronically controlled. Its mechanical. I believe it transfers more power to the outside wheel in a turn to keep from loosing traction. It will balance power between both from wheels to maintain traction. That being said the Si's are torquey, I still have no problem kicking the traction control light on in first or around a corner in second.
i sold hondas for several years. the Si has had VSA for a long time.It has traction control. Not vsa as far as I know. Also non si models have a button to disable vsa. Si models do not have this switch.
They don't. Did you even look at the regular civics? They have the same icon on the button even tho it's in a different location. It does not say "VSA." Some models did have buttons marked VSA, but the 12 civics only had icons.I was under the impression that button disabled only the traction control. Then why do the other models have a button clearly marked vsa?
