ADExternal
Lvl: 99 Modifier
More to come, more to come......
Always a seemly endless pitMore to come, more to come......
http://9thcivic.com/forum/threads/2013-rearview-camera-a-first-look.6098/So i am SOL if i have navigation...... fantastic.
I'll try to do more simple but effective mod DIYs when I get the chance Privman. Im sure there are plenty of things you can do!
Use the "upload a file" button, which is next to the "post reply" button when typing your post. That way your pics show up.If you plan to install the camera in a sedan, ...[snip]
Definitely will keep this in mind. I just received the 12 SMD yesterday. Will start my install when it gets a bit warmer. I will take photos of my progress and post in my build thread.If you plan to install the camera in a sedan, you should make an additional modification to clear the garnish. As you can see in the first pic, the camera could not clear the garnish with just the mod as proposed by AD-External. You need also to lift the camera from its base about 10mm to fit after you displace it. Pics 2 and 3 show the final result. I did it last november and it is a very useful mod.
