______________
Yes, absolutely. There was tons of TBN remaining (7.4) and the oxidation was acceptable around 54%, especially given the stout DI package. (DI package =
http://www.bobistheoilguy.com/whats-in-your-motor-oil/)
Keep in mind the lubricant used was Amsoil's
Group V 0w-30 built from an expensive combination of esters and rated for up to 35,000 miles, or 17,500 miles under severe conditions. Most well built synthetics are 'only' (no slam intended)
Group IV polyalphaolephins, or "PAO" for short. But there's nothing wrong with a good PAO. On the contrary: A few Amsoil PAO's are still rated for 25,000 miles or one year, and considerably more if bypass filtration is used, naturally. Interestingly, Mobil 1 -- back in the day when it had a 25,000 mile warranty, was also a
Group IV PAO. Now, however, Mobil 1 is only an API
Group III hydrocrack... a definite step down. That doesn't make it a bad oil by any means.... it's just not designed for those super-extended drain intervals like before. That said, I've had no problem using M1 for 7,500 miles, although it is trashed by that point.
It's important to note that deterioration of TBN is not linear. So I prefer to play it safe by changing oil when an oil's TBN approaches 4, or when other warning signs appear. Your preferences will vary, of course... and that's perfectly okay.
Here's a representative slide showing the relative difference between a PAO and a polyol ester in one of ExxonMobil's industrial lubricant presentations in terms of reducing deposit formation. Even from one slide you'll see PAO's are great oils... but those made with esters are just a little better.
http://screencast.com/t/WMMsWZoc
For reference, a link to the full article is here:
http://utsrus.com/documents/seminary_doklady/exxon_mobil_pao.pdf
