If you are looking at weight reduction alone, I would start with lighter wheels if you haven't done so already. I believe stock wheels are about 25lbs each. You should be able to find some that weigh in around 15 lbs each.
Enkei  PF01 is 17.4 pounds in an 18" size, on closeout at Tire Rack.
OZ Alleggerita is 16.6 pounds in an 18" size as well.
Every pound of rotational weight to accelerate is equivalent to taking between 4-10 pounds off of the body. ( 1/4 mile ) Dropping close to 40 pounds of rotating weight is like taking between 160 - 400 pounds off of the body. There are many factors, and it's been pointed out that the higher the RPM of the rotational weight that is reduced, the more effective it is, compared to something with equivalent weight at a lower RPM.
Also, the distance from the center of rotation, the more effective weight loss will be.... meaning if you say could lighten the rotor by 3 pounds, or the tire ( the tire being larger in diameter ) the tire would have more effect. ( both turning the same angular RPM )
Wheels and tires are also un-sprung weight, which, when reduced will increase the effectiveness of the shock at damping the spring oscillation, and handling will be improved above all else.
Here's an article on weight reduction, however they were focusing more on weight reduction of the entire vehicle.
http://www.hotrod.com/howto/113_0310_weight_reduction/viewall.html
If you wanted to go all out without spending a lot of money, ditch the spare, the jack and handle, that should be good for another 40 pounds or so. If you have access to a lathe, you could possibly reduce the diameter of the brake rotors some, so that the rotor is flush with the top of the pads. The rotor hat could be thinned out some without losing integrity.
