I just got CREE bulbs for my reverse lightsCREE LEDs are the brightest LED bulbs in the market right now. I've seen people use CREE bulbs as their license plate lights. Lol. It's way too bright.
personally I think the stock ones are way too dimcan you post a pic? I want to see how they look. On my old 8th gen they looks sexy with 68smds.I just got CREE bulbs for my reverse lightspersonally I think the stock ones are way too dim
They're still on their way but I will when I install themcan you post a pic? I want to see how they look. On my old 8th gen they looks sexy with 68smds.
Nothing works as good in a halogen reflector type housing as a normal halogen bulb. They are designed to capture the light coming from the filament and direct it out through the lens in a nice wide pattern which is limited in height.
There are standards for tolerances on the location of the filament, but for the most part they are very close to one another. When you go and put a big fat LED corn cob in there, the reflector isn't doing you much at all. From the outside looking in, the color may 'look' better, but the proof is in how well the light control is and the pattern on the road. I find that adding a drop in LED will give you inconsistent lighting, streaky and hot spots as compared to a smooth beam.
The same issues with installing a plug n' play HID kit. They physically put out more light, but often the pattern isn't smooth as it is with a halogen.
