AlienPrime
hey guys! So i'm interested to get your opinions!
Our cars come with 55w 550 Lumen bulbs in the fog lamp housing
Getting a bit more output, we can throw a hardware store type (GE Nighthawk) 65w or 80w bulb in that will give us 600 lumen and 700 lumen respectively
Now we generally have two options with HID's. 35w solution and the 55w solution (generally)
Both of which can be expensive to get good quality sets..
35w HID's max at about 3400 lumen while 55w sets will output a max of approx 5000 lumen (assuming they are not chinese knock-off brands)
The best in between that's we've seen so far are LED type "bulbs"
KPlayground just released an 11w one which outputs a total of 750 lumen (essentially 100w bulb output without the extreme heat)
There are also 20w LED kits that produce 1000+ lumen and are still relatively cheap to buy.
Here are the 20w LED iJDMToy sells for $55 (supposedly 1150 lumen)
What are your thoughts on alternative lighting in fog lights? Worth going to 55w HID's in fog lamp housing or will higher wattage bulbs do the trick? Or... should LED's be a consideration since they are quite high output while still having low wattage/heat?
Tell me what you guys think!
3k
