CivicCanuck
1. Drop it on the ground, looks cool, but you pay a penalty by changing the roll centers, not to mention much easier to bottom out from the softer lowering springs.
2. Add heavy 18" or 19" wheels, and likewise heavy tires.
3. Instead of proper tire fitment, S T R E T C H those tires designed for a 6 1/2" rim onto a 9" ( or bigger ) rim... bead blaster + ether can and propane torch for more win!
Who needs to optimize your contact patch anyways?
4. Run way too high or way too low a tire pressure.
How to make your car FAST: look at the HPD IndyCar Civic Si coupe. Pulls 1.10G, look at the ride height on that baby... nice big gap between the tire and fender.
They even have the tire / wheel and spring rates listed. It's obvious that they are doing something right. Off the shelf wheels and tires, but there is no other information on the adjustable ride height ( coilover ) suspension other than the spring rate. Browsing the HPD website though, they do have adjustable top plates available where you can adjust the camber as well as the caster @ the strut mounting point.
Linky here: http://hpd.honda.com/innovations/street-projects/civic-indycar-pace-car
