CivicCanuck
I have been in two anechoic chambers, one at the Klipsch world headquarters / engineering center - Indianapolis, Indiana, and the other at the Klipsch manufacturing facility in Hope, Arkansas. If you are in one for long, you can hear your pulse, and if the lights are turned out, you will loose all sense of balance and fall down.
Listening behind a loudspeaker given a swept sine tone from high to low frequency is interesting, you can hear the point where the polars expand, and the sound wraps around the cabinet... this must be carefully balanced with eq for the intended application / distance from boundaries.
Here's a few real big 'uns.... chambers that is.
http://space.io9.com/spaces-on-earth-where-no-one-can-hear-you-scream-472629162
