mongoose221
Hey guys, sorry this took so long to get posted, just was very busy all weekend (death in the family), anyway, on to the posting.
disclaimer: the problems I ran into during this may or may not be had by others, I just feel the urge to include every little issue I ran into to help others in case they have the same. Any questions, feel free to PM me.
This is a catback installation, and while every exhaust is different, they are, in general, basically the same (the removal of the stock catback system is identical).
Tools Needed:
-a way to safely lift the car (i used 2 ramps for the rear, and jackstands up front, you may also use a lift, or other methods, either way, SAFETY is the key, you will be crawling under your vehicle, and putting plenty of force into these bolts to remove and install them, the vehicle MUST BE SECURE)
-12mm wrench (i recommend a ratcheting box end and a heavy duty shallow socket, and a heavy duty deep socket)
-14mm wrench (again, same as above)
Tools Recommended additionally to make your life easier:
-cheater/breaker bar for your wrench/socket (those cat bolts are on there like a mother******)
-PB blaster (pb nut blaster/etc is a liquid lubricant sprayed onto stuck on nuts/bolts... i love the stuff, google it!)
-gloves (rubber/latex or mechanics gloves, don't want no fingerprints on that fly exhaust!)
-goggles/safety glasses (you will be UNDER a dirty vehicle, you don't want junk in your eyes)
-lubricant (for the rubber hangars)
-xacto knife/box cutter (to trim the cat gasket)
-patience and a strong arm!!
box has arrived!
another box shot (that sounds dirty)
packed nicely
in the bags
out of the bags... ooo shiny!
detail of exhaust tip
Tools Needed:
box has arrived!
packed nicely
in the bags
