9thcivic Tail of the Dragon Part II: Official Information and Attendee Thread
We don't forgive you! :rotfl: I'm kidding.
Are you on VWVortex more? I'm on there too. ;)
Oh I should let you NE guys know... I will not be caravaning down but might be going back with you guys. Ill be in Louisville the weekend before so ill be driving over from there. Not sure about my return trip yet.
I've got a couple maintenance parts to go on... can't wait....
Same here
Me 3!
- Replace Driver's side window switch (drivers side window won't go up/down using the switch on the drivers side.) - can't replace just the drivers windows switch..
- Raise my rear coilovers (fix saggy butt/rear)
- Get an alignment
- Put the '12 WRX wheels/tires on before the dragon
- Change oil
- Replace passenger corner marker light
- Replace uppipe gasket (hope it fixes the screaming noise when WOT)
Me 3!
- Get an alignment
- Change oil
:pray: I hope
Since pretty much everything on the G35 is addressed, the only things I have to do are:
- flush brake fluid
- get a plenum spacer (maybe)
- flush P/S fluid (maybe)
Yeah quite a bit of people have told me that they think it's an uppipe gasket/leak. It's been doing this since after I got tuned (2008/2009).
Oh I forgot one thing to add to my list:
- Fix the squeaky A/C pully/compressor. When the A/C compressor kicks on it squeaks.
Replace brake lines and clutch line, new fluid, new brake pads and change oil and trans fluid my list
heh mine is almost the same.
New brake pads/shoes F & R. New brake fluid, PS fluid, trans fluid, oil, tire rotation.
Since we're only a month away, all I have left to do is:
VOLVO FROM HELL:
Front upper strut mounts
Bilstein Struts
Front sway bar end links
Lower control Arms/ Ball joints
Inner and Outer Tie Rods
Front Hubs
New axles
Upper Strut Brace
H&R Springs (F&R)
Upper Trans Mount Bushing
Lower Trans Torque Mount
Bilstein Shocks (rear)
Upper Rear Shock Mounts
Rear Control Arm Links
Rear Delta Link Bushings
Front Rotors, Calipers and Pads
Rear Rotors, Calipers and Pads
ATE Blue Brake Fluid
4-wheel alignment
Engine Oil & Filter
JILL'S AUDI:
APR Stage 1 ECU rechip
Bilstein Struts
Upper and Lower control Arms
Front Hubs
New axles
FCP Springs (F&R)
ATE Blue Brake fluid
4-wheel alignment
Engine Oil & Filter
I might not get it all done but we'll have fun anyways.
I think last years dragon was the beginning of the end of my brake and clutch lines
