RHelton10
I want to change the 12V power supply in the front of my '13 4-dr Si to constant power instead of the factory key-switched power. I've done this before in other cars, but have always run a new wire from the fuse box to the 12V power supply and used the existing ground wire.
I have a new idea, but wanted some input from you guys that deal with the electrical components more often than I.
Is it possible to find the fuse for the 12V/Cigarette Lighter, and just run a fuse-tap from that spot over to another constant power fuse? Basically, let 1 fuse supply power to the other fuse that is, from the factory, only on a key-switched power. Does this make sense? You guys see any issues with doing this?
